Never realised I wasn't reaching top speed until i used my GPS last year. Turns out that my bike for the last several years has not been able to reach what i believe is its top speed. It tops out at 125 kmh (77 mph). I always though my tacho was off and thought the needle just didn't pass 5k RPM. However now I realised the bike isn't going over 5k RPM
I dont want to set new land speed records but i do want the bike to operate as it should. Below are some details about my set-up and all the things i have tried so far to figure it out.
PS I have been using the awesome checklist posted in this thread : http://www.xs650.com/threads/low-top-speed.46070/
My bike:
Things im not sure about, I've got a 17t front sprocket and a 31t rear. I know that the rear one is not original. Could this be robbing me of power? I see this combination rather often at the forum, not sure if its geared too tall?
something else i worked on is the carb settings. I red the carb guide again, and realized that >5k RPM is mainly the main jet. I changed form 145 to 140 and did a test run. Now i was able to get up 132 kmh (82 mph) @ 6k RPM. is was in 4th gear. if i go to 5th i cant go faster.
Today i tested some WOT runs in 3rd gear. from 5 to 6k RPM takes some time, then i got it very slowely up to 7k RPM. maybe try a smaller main like 137,5?
sorry for the long read
but maybe you guys have an idea where to take it from here
My bike:
- 1980, however not original.
- 650cc
- TCI ignition
- 18'' rear wheel
- 2 in 2 high pipes (scrambler style), Heiden tuning megaphones
- bs34 carbs, large K&N filters
- main jet 145
- pilot jet 45
- I live at sea-level
- new plugs
- checked the cam chain tension
- set the valve play
- changed the oil and filter
- compression check cold/no oil/ WOT: left and right around 125 psi.
- checked the brakes if they were dragging, they are not.
- pumped up the tires to >32 psi
- checked if the drive chain was not to tight, its not
- throttle cable is fully opening
- put some good fuel in the tank
- checked for holes in the diaphragm by putting my finger over the oval hole in the carb, the go down very slowly.
- While stationary, if I rev the engine it zips up to the redline.
- I removed the air filters to see if the slides fully raise when stationary, they do.
