trance
OK, this is a brand new bike to me. Haven't even ridden it a mile. Changing the oil, cuz that's what you do with a new bike.
The oil screen (side cover) was CLOGGED with metal shavings - is this in any way normal? I can't even imagine how to get them all out. I'm soaking it in gas overnight, but by now, there are metal shaving on BOTH sides of the screen instead of just one. I'm thinking I have to order a new one, unless you guys tell me it's possible to clean this one.
The sump screen is torn (I've already read up on how to repair. Ironically enough, the screen itself is fairly clean. But there were many chunks of plastic/rubber in the sump - two were 1" long !!!. I assume these are the cam chain guides. Given how much was in there, does that mean I need to replace the cam chain guides?
I did adjust the cam chain before the oil change, and it did take a lot of adjustment. I hope this means the top end quiets down. Valve adjust is next.
The bike does have good compression (155/153) so I'm going to *assume* for now that the metal shavings are from:
1) maybe the P.O. hasn't changed the oil for a long time and they are normal
2) maybe the P.O. has never changed the oil
3) maybe the P.O. wasn't lying about having the engine rebuilt (I'm sure this isn't true though, because the engine is too dirty to be rebuilt. maybe a new head...)
dang I'm stressing about this. Did some searching - my situation is similar to this guy:
http://www.xs650.com/forum/showthread.php?t=11611
my upper filter looks similar to his, except I didn't have any chunks of plastic in the upper filter - and the metal was much smaller, very fine.. the chunks of plastic were in the sump and are mostly 1/8" - 1/16" or smaller, but 2 large pieces about 1/4" wide x 1" long. I do think the cam chain was making noise before this, but I hadn't restarted the bike before the oil change to see if the cam chain adjusting quieted it down.
Someone please tell me if I need to replace the cam guides. If I do - how do I do this? This is serious stress. Ouch...
