Good thing we change oil frequently eh?
Add in; running motor oil through gear sets........
I tend to go longer on madness cuz (real oil filter) but....
Had a friend in conco-phillips which was a specialist in oil and viscosity - his word of wisdom was “any oil is better than no oilNow I don't really wish to throw a hat in the ring here...... But anyway.
I was a professional machinery specialist in petrochemical, oil and gas etc... for almost 50 years. How many machines did I see fail by using an incorrect grade of oil? Not one. Sure, damage was sometimes done but there was never a single catastrophe.
The number of catastrophic failures from no oil? Many.
My takeaway is not to overthink stuff.
100% yes.Had a friend in conco-phillips which was a specialist in oil and viscosity - his word of wisdom was “any oil is better than no oil”
I'd agree, and whatever new oil you put within reason will be much better than nothing and better than old or oil of unknown provenance & age but generally we tend to do a bit better than that and there's so much choice on the shelves - tend to put Putoline V-twin oil in Miss November thinking an oil developed for the rollers/ball bearing engines found in V-twins might suit an XS's vintage engine better than oil sold for modern plain-bearing motors?100% yes.
Anything that "scrubbs" or slides slowly back and forth as you mentioned is the most critical.As the XS has ball/ roller bearing crankshaft and camshaft, I guess the most critical parts when it comes to lubrication would be cams and rockers? Or am I wrong?
Somebody once tried to explain it to me why, apparently you need different polymers to resist the averaged-out loads across a plain bearing than the much higher loadings on small surface areas that you have in rollers and balls. Or sommat. But any oil sure is 100% better than none.. . . an oil developed for the rollers/ball bearing engines found in V-twins might suit an XS's vintage engine better than oil sold for modern plain-bearing motors?
Phosphate kills the cats, not zinc.
