Oil leak on my 1979 yhamha xs 650
big dog 1234
XS650 New Member
WI
i have had this problem for a couple moths now and i cant seam to figer it out can any one help me?
the big problem is a oil leek on my bike and i have tried most of the seals on the left side of the bike because that is ware the oil is coming from i have replaced the main shaft seal or the crank shaft seal idk what it is called a few times. when ever i ride it oil is slung all over the exhaust and the rear tire also the rear fender i have also replace the clutch rod seal more then 4 times and i cleaned up the rod well i don't know why it keeps leaking can any one help me please???
If the oil is from the breather, what level of oil do you run in the engine? Too much and it will be blown out. I only fill with 2 litres which puts the level at the bottom mark on the dipstick. More oil definitely doesn't mean better.
Other leaks that can affect the left side of the bike are - clutch pushrod seal and worn guide bush, leaking from the sump plate, leaking copper washers under the lower crankcase dome nuts, leaking from under the sprocket nut, leaking starter gear train cover gasket. I had all those on my 650D and I had to do each one in turn to get an oil free motor.
1. What have you got on your breather at the back of the engine? Originally there was a pipe which fed into the air boxes. Mine has a hole which implies that originally a pipe lead from the breather to just above the front sprocket which would mist the chain.
If you have nothing then you may find that some oil mists from here. I fitted a length of pipe with the intention of fitting a catch can or feeding it to the chain, but once i did this I found that there was not even a mist. I can only guess that when the engine "breathes out" mist fills the pipe volume and when it breathes in it goes back. If you have nothing it goes out and never back in. I now have a one way valve fitted on the end of eight inches of pipe tucked behind the side pane. They are used on car brake systems. Look on eBay for one.
2. But a more likely candidate is the countershaft area where you've replaced the large seal.
There has been much discussion here about Yamaha increasing the torque specs over the years for the large countershaft nut, and also much reporting here of people finding it loose even though it has (or should have) a lock washer with tabs that are bent over.
Oil can leak from here it the nut has not been done up sufficiently. But I also found that there is a castlelated washer which in my case was badly deformed and interfered with the assembly pulling down correctly. I couldn't get a new one I recall, and so cleaned it up with a hammer and a small file. I intended to replace it but its still there and no leaks.
The problem with oil is it migrates and you end up looking in the wrong place. Clean everything scrupulously and then go for a short ride so you can actually see where it is coming from. It occurs to me that a light dusting with talc might identify where it runs from one area to another.
I actually don't know very much, but like Isaac Newton "I have stood on the shoulders of giants". (Have had enormous help from this forum)
Hope this helps.
Dave
Hope this helps.
Dave
+1 on countershaft
+1 on baby powder
