hjpaul7
I have 78 BS38 stock carbs.
My first time ever touching a carburetor, I have read the carb guide a couple times, got them off. Took the float bowls off and the floats. I can hear fuel sloshing around the floats so I know I have to replace them. Also got the two pilot jets out I believe.
I should probably back track and say I'm cleaning these out and rejetting to use with UNI foam pod filters. So replacing the jets would only be the two main, and two pilots? Along with moving the needle. But I can't seem to locate the main jet according the carb guide.
Also I pulled this guy out, not sure what it is. Pictures below.
Help?
EDIT: Okay, I'm the second photo I think I realized I pulled out the needle jet? Do I need to replace these as well?
Help?
