Rather than just rushing ahead, changing the points and hoping all is good to get out for a ride on this Holiday and the the nicest day of the year we've had so far this summer, (enough griping), I decided to spend today's shop time being schooled. I always told my kids, 'anytime spent learning something new is time well spent', and it's high time to stop being intimidated by these electrics.
Fired up easy, first kick. Hanging/ erratic idle apparent from the get go.
Have you put a timing light on it and watched, especially at idle and revving up and down a bit?
This is a good one. Watch the actual strobing of the light. If the timing light is a good one, the strobing should be perfectly repetitive, with no skips in the flashing. Problems with points, condensers, coils, and coil wiring will demonstrate inconsistent flashing...
Nice steady beam, no skips in the flashing. But I expect my made in Taiwan timing light may not be the best.
But it sure showed how the advance weights weights are hanging up. Man, it's the things you don't put on the list and forget to do that come back to haunt you. This might be a chicken and the egg thing though. Are the advance weights hanging open causing the high idle or are the points condensers bad, causing the high idle and weights to hang open?
The weights will snap closed if I quickly snap them, but if I slowly remove my finger they will hang open. Turned engine to get points off ramps. Advance rod was lubed with high moly grease this spring but may need to shorten the springs. Will see what happens after new points are installed and address it then if necessary, unless anyone thinks I really should do it now.
Timing check: Left side - idle at right line: slightly retarded as per 5twins recommendations, full advance no bounce past the line
Right side - idle at right line, full advance some bounce past the line
Timing issues will get dealt with and reset after new points are installed.
Any "unusual" arcing at points?
Yup, on both sides. More so on the right side which is the side running rougher. (Go figure) Left side nice smooth steady idle.
Looks like gggGary, that you and 5twins nailed it on this one. Glad new points came in the last order, just to have on hand.
Have points ever been changed or is it on some other ignition?
Stock ignition, probably stock points.
Has there been a sync done while running?
Not yet
spark plug caps tested for correct ohms?
New 5K caps and new wires
just for kicks n grins? try a set of BP6ES ,1 grade hotter plug.
Will get some to have for testing.
ground wires correctly placed on upper motor mounts?
Main harness to coil mount ground good. Engine ground on cylinder head steady plate good.
Had a hard time finding info on testing condensers. Might be in the Yamaha Factory manual but it's at buddies and couldn't get it back today.
Found this link from an old thread:
http://mgaguru.com/mgtech/ignition/ig129.htm
My old analog meter would not read anything, no needle sweep on it's only 2 ohm settings, so used one of my digital meters.
Fortunately have a new condenser from a recent parts order just to have on hand. Meter climbed to infinity.
Once again, no Factory Manual today, nothing in Clymer, but Haynes says:
"To check, separate the contact points by hand when the ignition is switched on. If a spark occurs across the points as they are
separated by hand, the condenser associated with that set of points can be regarded as unserviceable."
Yup, both points. So I don't know what to think. Passed the first test, failed the second. I'm going to replace it anyways but is there a better more definitive test? One manual mentioned charging by hooking up to a battery and then testing but I felt like that was similar to what was happening in step #4 on the above mgaguru.com post.
Yup, over 12 volts on R/W wire to coils.
Also tested coils to see what's up. Might be tests in factory manual but did some I found on the site. I have an extra used coil so tested that one as well.
There were other tests that I came across that I couldn't figure out how to do. Based on my searches and these findings I think all is good. If I'm missing anything or any other tests that should be done, please let me know.
Put an inline spark tester on and watch in dim light.
Gotta get one, stores were closed here today....lol.
Always good to get them running but for a bike that I want to put miles on it's hard to beat a Pamco then the e-advance...... It's fun to spend other peoples money.
Looking at XS650Direct I think this will be north of $400 by a bit. It's in the plans and on the want to do this list, gotta start saving my pennies. Before I take that move I really want to get this running well in stock form. Maybe I like a challenge, maybe I'm a masochist? Probably both.
So, next shop day available, install new points and condensers.
Thanks again everyone for your help and support.
As always, any comments, suggestions, corrections welcomed.
