I'm sure everyone has had one of those days in the shop. Started on re-assembly of the top end. Using Jim's excellent step by step thread in the Tech section so I don't forget any thing. Got the pistons in the cylinders, cylinders down on the studs, and pins set in the rods.
I then lowered the cylinders down onto the top of the case. It didn't go down quite all the way to sit flat on the gasket. I figured it was just hung up a bit on the alignment dowels, so I gave it a couple of taps with the rubber hammer. No go. Hmmmm. Seems to be rocking a bit front to back. Looked down between the cylinders and damn. The top of the center cam chain guide, which is essentially an aluminum block, is hitting a protruding ridge on the side of the cylinder casting, preventing the cylinders from setting down all the way. I pulled out the old guide that I replaced and sure enough there was a gouge in the top in that same location. Maybe Yamaha didn't notice the interference and just torqued it down. I didn't want to take the chance of either damaging something or it not sealing well at the bottom. So, everything came back apart. I removed metal with a die grinder a bit at a time, and kept checking until I had sufficient clearance and the cylinders sat down fully on the gasket.
Then back to where I started. Nothing like having to assemble the pistons and cylinders twice in one day. I guess practice makes perfect.
