Kickstarter acted up again today. I think it was the tension clip that slides the starter gear in to engage. I pulled it out and squeezed in a vice to tighten it up. Working again, we'll see if it lasts. I also ordered a new one just in case.
I understand you wanting a "true" restoration, but some things need updating. The regulator being one of them. You can build your own reg/rec for under 50 bucks. It's reliable and no one will ever see it. Hell, you can even leave the old one installed and ready to hook back up.I've been riding the bike as much as possible to break it in. Bike starts on the first or second kick, and when warmed up, idles great. Lots of power through all the gears. Just a joy to ride. Have been working out a few kinks. I did have to replace one cam seal that was leaking a bit. New seal solved that issue.
Today, while riding I noticed that the headlight was out (low beam). So I switched to high beam. By the time I got home, the high beam was out. Checked the headlight and both beams were burned out. Checked voltage and at about 2500 rpm, I was getting about 15.5 volts. Likely fried the bulbs. I checked the voltage regulator according to the manual by reading the ohms across the various wires, and it all seemed within spec. I then tried adjusting the voltage according to the procedure in the manual. That is, adjust the set screw on the regulator, then start the bike, pull the positive battery lead, and read voltage across the positive wire from the bike and negative lead. I did this a couple of times and got the voltage down to about 15 volts at 2500 rpm. I wanted to get it a bit lower, so I went through the process again, but this time, the second I disconnected the positive battery lead, the bike died. I re-connected the positive lead, and tried again. Same thing, died the second I disconnected the lead. Reconnected the lead and started the bike again. Before I had time to disconnect the positive lead, I heard a "snick" and at the same time I saw the taillight get real bright, then burn out. This event also burned out the gauge lights. Curiously, the neutral light survived, as did the 20 amp fuse. At that point, I hung it up for the night before I did any more damage. Any ideas on what is going on, and what to check?
Are they Tygon?When I disconnected the fuel lines, they were both almost rock hard already.
No, not Tygon, but supposedly fuel rated line. I'll see if I can find some of the line Gary suggested; we have a garden equipment shop here in town that will likely have it.Are they Tygon?
Yes, it is.Is this ground jumper in place?
