Man I'd be pissed at the jerk that sold you that thing with a jacked up title like that!
+1 on that. Although my heat gun gets plenty hot enough... might try that before the big blue gun.Heat the base of the stud up "real good: with a propane torch. THey use some serious thread locker on the those at least on the later years.
Pistons look good?
They changed the conn rod when they deleted the needles. Not sure about the piston hole. Look in Tech... top of page. @650Skull 's excellent "differences" thread.I know that Yamaha deleted the needle bearings at about serial number 3200. Question is, when they deleted the needle bearings did they use a different piston with a larger diameter wrist pin to fit the existing connecting rods, or did they use a different connecting rod with a smaller diameter small end to fit the existing piston/wrist pin set up?
I looked in that thread several times; I knew there was con rod information in there somewhere, but I just couldn't find it. Just looked again and sure as shinola, it's in there. I must be blind sometimes. I suppose I could try to find a later crank and rod setup, but really wasn't planning on splitting the case. Maybe the needle bearings will just stay.They changed the conn rod when they deleted the needles. Not sure about the piston hole. Look in Tech... top of page. @650Skull 's excellent "differences" thread.
You could even weld some sort of lever to it.... since it's trashed anyway.What do you plan on using to extract that stud? Do you have a tool or you just gonna try a double nut. Although I guess if it’s a change out a pipe wrench would also work…
I did chase the threads in the case with a tap.You might run a tap on those stud threads
You said "brake lining" but I assume you mean the drum?Some pretty deep grooves and pitting in the brake lining of the rear hub assembly. Any opinions on this? Just clean it up best I can and go with it, or try to find a replacement?View attachment 343506
