I’ve found with crimp connectors that have heat shrink tubing on them, you get what you pay for. I’ve purchased inexpensive kits from Amazon and the metal part inside is quite soft when you crimp them and leaves me with a questionable connection.
With the limited number of these connectors I use, I now buy them from an automotive supply jobber. The metal part is much more substantial and I get a nice, firm connection. The heat shrink sleeve doesn’t split when crimped and the sealant melts easily and evenly. I don’t think I’ll ever use the cheaper ones again.
Btw - if using any heat shrink connectors or tubing, I always use ones with sealant - it protects the joint well and if the plastic happens to perforate when crimped, the sealant will often flow to fill in the gap.
