I see the great images explaining the differences between 70-79 and 80-84 stators.
Step 1
Fresh store-bought battery.
Step 2
Does not pass slap test. Does not exhibit any magnetism.
Step 3
Shorted green wire to ground (see photo)
Battery read ~12.8V relatively steady when running
Battery would not go over 13V
Revving to 4,000 RPM
Step 4
12.50 across battery with key on
12.12 from brush screw brown wire to battery negative
12.53 across battery with key on
12.21 from brown wire at plastic junction to battery negative
Step 5
Definitely not getting 14.5 at the battery. 12.8 max revving at 4,000 RPM
Measures 5.6 ohms on stator rings
Step 6
#1 white wire 7.85V
#2 white wire 2.69V
#3 white wire 7.92V
Popped stator off to see if it was blown out before reading Step 7. This little roll bearing fell out. I'm not sure where it came from.
Stator looks very dirty.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
#1 white wire 7.85V
#2 white wire 2.69V
#3 white wire 7.92V
