OK... so, this is a fairly common problem with the early tanks. One of the ears that hold the pivot pin on the cap latch is broke off. We know that
J B Weld works for this application (more in a bit).
The big problem with epoxying aluminum is that the aluminum starts to oxidize almost immediately after you clean it up... and that oxide gives us a very poor bond. This tank and ear has been bead blasted and all the prep work done... ready to reassemble.
So, with an appropriate pin at the ready and the epoxy mixed and ready, use a stainless steel brush and scrub the bonding area.... make it shine. Now there's practically no oxides to contaminate the bond. Stick it together. Don't dally around... stick it as soon as possible.
The puddle just aft of the ears is where I used some of the J B Weld to fill in the rust pitting.... just an added protection to keep it sealed from gas intrusion. after it's cured, I'll add some more J B Weld and create a fillet around the ear for added strength.
Think the bond ain't strong enough for the gas cap? Think again. Or ask Bob. This is the exact procedure he used on his tank. When I got it for painting, there was a discussion on whether or not it was strong enough. Here's my test that shows how strong it is. 'Nuff said.
That was done about 2 yrs ago.
@WideAWAKE owns Bob's XS2 now and far as I know... it's still holding.
