Part identifications
Calev
Salt Lake City, Utah
I’m just about done with a top end rebuild and found some pins that I forgot to document/label. These could be from a different project on my bike but I just can’t remember from where. I know on pin is from doing a PMA Banshee mod but not sure where the other two are. I did disassemble a broken speedometer so I’m not sure if there are left over parts from that. I’m also fairly certain I reinstalled all pins pertaining to the top end rebuild.
Any recognize these guys?
Here are approximate measurements from left to right:
Length: 12mm, 21.5mm, 14mm
OD: 3mm, 5.5mm, 3mm
Thanks Signal. I double checked the mechanical advance and that has the proper pin already. I know it is not from the oil pump drive or shift star ratchet pin as I did not split the case and mess around with that.
The left pin is from a chain pin when I remove the cam chain. Still not sure what the middle one is but I am confident it does not pertain to anything with the top end or anything with the motorcycle.
