1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
Parts Cleaner Fluid
Discussion in 'The Garage' started by BowlingSS, Oct 19, 2021.
  1. BowlingSS
    BowlingSS XS650 Junkie XS650.com Supporter
    My 20 gallon parts cleaner fluid is getting old. What is everyone using? You know what I am cleaning.
    So far three XS2’s, two 73 TX650’s and one 1981 XS650SH. The fluid is getting really dirty.
    Thanks guys.
    Bill
    Boog and Mikey like this.
  2. fredintoon
    Hi Bill,
    Low-cost cleaning solvent is available from a filling station's diesel pump.
    Boog, homer and Mikey like this.
  3. Mikey
    Mikey got muscles in his head that ain't never been used XS650.com Supporter Top Contributor
    Kerosene at a fleet / farm store filling station pump
    Boog likes this.
  4. fredintoon
    Hi Mikey,
    Kerosene at a farm store is same stuff as Diesel fuel at a filling station but costs less because it's taxed less?
    Up here the tax Nazis have color cards to test non-farm vehicles' fuel to see if it's dyed pink (farm use only) or not.
  5. jetmechmarty
    jetmechmarty Project collector XS650.com Supporter Top Contributor
    Where is your parts washer parked? If it's in an attached garage I would be inclined to use soap rather than something that can feed a fire.
    [​IMG]
    Boog, Adamc and Mikey like this.
  6. Jim
    Most modern parts washer tanks have a fusible link holding the lid up... at least mine does. At least that mitigates the fire danger some.
  7. gggGary
    gggGary On the road of life I'm a speed bump. XS650.com Supporter Top Contributor
    And you need to check if the pump is designed for water or petroleum based solvent.
    Boog, jetmechmarty, kshansen and 3 others like this.
  8. bosco659
    bosco659 XS650 Junkie Top Contributor
    Great cleaner but can do nasty stuff to aluminum if left on too long. Also hard on electronic devices like sensors. Found out the hard way on my wife’s Miata. Decided to wash the engine so I gave it a liberal spray with Super Clean and it took out a couple of sensors. Also removes your fingerprints if you use it without gloves on. Lol. I still use it but with caution.
    Boog, GLJ, Mikey and 3 others like this.
  9. Mailman
    I can attest to that, when I was a welder in a fleet garage, I was using an angle grinder on something and I was about 8-10 feet away from our parts washer. A big one with a 50 gallon drum under a big basin, anyways the sparks from my grinder started a fire in that basin and man it grew huge in a hurry. Before any of us had a chance to grab a fire extinguisher , that fusible link Jim was talking about , melted and that lid slammed shut and immediately extinguished the flame. It was pretty impressive really.
    I also caught a gas pump on fire once, that was a lot more exiting! :yikes:
    Boog, RustiePyles, GLJ and 4 others like this.
  10. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    The world became a safer place when you went to work for USPS. :laugh2:
    Boog, MrBultaco, RustiePyles and 2 others like this.
  11. Mailman
    My safety improved also! We won’t talk about run away mail trucks! :laugh2:
    Boog, RustiePyles, Jim and 1 other person like this.
  12. gggGary
    You too?
    Boog, Jim and GLJ like this.
  13. Mailman
    Boog, RustiePyles, Jim and 2 others like this.
  14. MacMcMacmac
    MacMcMacmac Failed Hedonist.
    Varsol, AKA Stoddard solvent.
    It isn't very flammable. I've seen an angle grinder discharging sparks directly into a parts washer with it in it and nothing happened.
    I used to clean parts in it for hours some days, with no gloves. I had no adverse effects. However I seem to have been sensitized to it over the years, so now even brief exposure gets my skin broken and burning, so use gloves no matter what you use. It's not odorless by any means, but is surely light years ahead of diesel, aka, the stench that will not die.
    Super clean will take your skin off. It has sodium hydroxide in it, which is lye and sodium metasilicate, which is also corrosive. We have a 208l drum at work, and under the tap used to dispense it, it has dried out into a white crust. It has dried out and split the polypropylene drum dolly it is held in. Nasty stuff at full strength. It will likely destroy any rubber seals and hoses in short order.
    Boog, BluzPlayer and gggGary like this.
  15. RustiePyles
    RustiePyles Semper Fortis XS650.com Supporter Top Contributor
    I'm using PSC1000, I top it up with kerosene and mineral sprits mixed. I also occasionally strain it through coffee filters when it gets to dirty. I keep a big magnet on the bottom of my parts washer to collect ferrous debris.
    Boog, OHRider, ThatXS650Guy and 3 others like this.
  16. ThatXS650Guy
    ThatXS650Guy More Sparky than Speed Racer XS650.com Supporter Top Contributor
    854
    2,184
    243
    North GA
    Kerosene. There's a station that sells it by the gallon in Lawrenceville.
  17. jetmechmarty
    I use it often, but I am cautious with it. Full strength, it's pretty good at removing paint, especially if it was sprayed from a rattle can. I'm also aware that it eats aluminum. That said, I don't think I've ever done damage with it. I've always diluted it, and/or thoroughly removed it with water. Super Clean sure does get after the grease! Be careful what you're cleaning with it.
    Boog, Mikey, bosco659 and 2 others like this.
  18. ThatXS650Guy
    854
    2,184
    243
    North GA
    Drove by the Kerosene station in Lawrenceville. Kerosene is $6.99/gallon which is quite a bit more than the last time I bought it (2018).
    gggGary, Boog, Mikey and 1 other person like this.
  19. RustiePyles
    :eek:only $4 a gallon in KS. Still better than the $11 a gallon stuff that Home Despot sells.
    gggGary, Boog, Mailman and 1 other person like this.
Share This Page
