PickleX Rust inhibitor, Does anyone have any experience using this ?
John Regular
dumb ape with a hammer
oregon
I have been dealing with surface rust on parts of my frame that PO had ground off tabs and brackets
IMG_1468[1].JPG. I'm in the process of getting the bike running and don't want to strip the frame down to paint just yet so I'm looking for options to control rust. I was just going to use WD40 and steel wool but don't want shit sticking to it. I want something that can be brushed on so I don't need to mask a bunch. After reading some funny arguments on chop cult I found this stuff and it sounds too good to be true.
I would love to keep a raw steel look on another project that I have. I used Locktite rust neutralizer but its more for painting over rust and is kind of an ugly finish.
So what have you used in the past? Oh and Though I don't think that this group will have a problem like this, try not to argue over clear coat.
Evapo-rust makes a water based rust inhibitor. I used it on my cast iron Norton barrels and was very happy with the results. No flash rust at all and they sat for quite a while.
Mind you it was in a heated shed. Not sure how effective it would be outside.
I use Evaporust as well. Works well for rust removal but as an inhibitor I’ve had mixed results. Some parts will stay rust free for a long period of time but others rust in a reasonably short period of time. I think it’s best to paint parts after rust removal or spray them with a good inhibitor like ACF50.
The last time I washed an XS650, I sprayed it liberally with WD40. Not the chrome and paint, but much of what isn’t, including the engine. I’m a little surprised at the result. I’m riding the bike regularly. It stinks for the first few errands I ran, but I believe I like the result. It’s doesn’t appear to be collecting dirt and appearance is enhanced. I’ll probably do it again next time.
That's what I am going to do, it's been keeping that Pandemonium tank I bought a decade ago? or so, in relatively good shape even if I have to clean dust and cat hair off it every once in a while. I will have to strip the whole frame of everything if I ever do get far enough to get it painted anyway. I just need to keep it from ending up all pitted like the CB125s frame. Does that make it a pit bike?
Using the W800 at the moment and there's no salt right now, only a matter of time though, but the roads are cruddy and slimy in places so the bike gets pretty filthy. But reading your report maybe my post ride routine should be a quick wash followed by liberal spray of WD40 and we'll see how that goes.
Poor old Polly
Poor old Polly
I just did an oil change on my Ford. Upon completion I liberally sprayed WD40 on engine, transmission, exposed fasteners, etc. I’m interested to see how all that looks after another 5,000 miles. The area is protected by a belly pan.
Poor old Polly
They don't use salt on the roads in Oregon, thank god, I've seen what it does just on the coast though.
