Messy work shop?
Less likely to be burglared.......it's what I tell me self.
It all depends how you want the bike to feel when the light turns green. I find 17/33 to be good on my Special, especially keeping up with traffic. My preference is no doubt 17/34 and that was what my bike came with.I've read that 17/32 is good and also pretty widely used?
This is sounding like what I'm going for!I've found 17/34 running an 18" rear is ideal for myself. I've had 17/32 with a 16" rear wheel but more downshifting was in play.
This is running on secondary roads with straightaways few and far between and max posted speed of 55 mph......I rarely go above 70 but the throttle says there's more to be had if I was so inclined........I try to keep it below my age.
Great info thank youI'm running the 17-32 combo on my Special with it's 16" wheel and like it. I tried the 32 on my Standard with it's 18" rear wheel and didn't like it. For the 18" wheel, I find a 33T is ideal. Here's a chart showing the top speeds with various sprocket combos. As you can see, the 17-32 on a 16" wheel is very close (only slightly higher) to a 17-33 on an 18" wheel .....
What is real nice about the cable driven tachometer on this motorcycle is that it is driven by the oil pump. If it’s indicating, the oil pump is turning. Otherwise, I don’t see a problem with no clocks at all. I know when I’m speeding. I don’t need a needle to tell me.I have a question about the tach drive, so I'm missing the full assembly and don't have any clock either. Would buying a blanking plug to delete it be fine and then use a GPS speedometer on my phone or is it worth getting a traditional guage?
Thank you, I was about to do this but an awesome member of the community has sent me the parts I need completely free of charge!Set up a search on Ebay and then oneday a tacho drive may turn up at a price you are prepared to pay. An alternative could be the blanking plug and an electronic tacho run off the 12V power lead to the ignition coil. Just depends what you want. Plenty of time to decide and not very inconvenient to remove the side cover at a later date to install a tacho drive.
Keep up the hard work...![]()
Oh, you can easily get a new nut for that, the problem lies in getting it on.So ....do I need a full new line or can I get a replacement nut for it?
Update!
The shim washers turned up so tonight I found time to reinstall the clutch basket and also checked all the piston, ring and bore tolerances which were spot-on so put those back on as well!
I came up with a Tach/HourMeter that has only a wire pickup wrapped around one plug wire. Internal watch battery quarter sized lasts 3 years the say. 3/4" x 2" display. It's a fools errand to run this motor much beyond 5500-6000rpm so a tach is window dressing, but, handy for tuning hence my little digital.Set up a search on Ebay and then oneday a tacho drive may turn up at a price you are prepared to pay. An alternative could be the blanking plug and an electronic tacho run off the 12V power lead to the ignition coil. Just depends what you want. Plenty of time to decide and not very inconvenient to remove the side cover at a later date to install a tacho drive.
It's a fools errand to run this motor much beyond 5500-6000rpm so...
