Mike's sells both a big bore and a stock bore with big fins.
One way to get a rough idea of the cc's is with a compression test.
I rebuilt my 75 engine as a 2nd over 650. It had 165 psi compression just after I got it together, full of assembly lube, no carbs, on the engine stand, cranking wit e-start.
I rebuilt it with Mike's 750 big fin kit, same circumstances and got 195 psi.
The stock compression ratio of 8.4-1 or so gives you the 165 psi, Mikes kit is 9.5-1 and gives the 195.
So a compression test if you get around 150-160, good chance the engine is a 650, Get 180 or better and it's probably the 750.
