Bought this used and had buffed out some scratches on my big slow speed buffing wheels with plexiglass compound. Needed to put 150 miles on today and it looked like rain. I had only 45 minutes before I had to leave but thought heck I'll try to mount it. Had it on and ready to ride in 10 minutes flat. I took tools along in case it moved but it was rock solid, never budged a smidge. I did have to improve the position, I had it a touch off center but that was on me and it was easy to adjust. On the XS650 it is fully below eye height. I have it angled back pretty good and the wind hit about mid helmet. Since i ride with a full face that is great compromise. It did increase wind noise slightly from no shield, there's a bit of turbulence at the helmet sides. Great addition, amazingly easy on off and I like the looks, two thumbs up. Mailman did you install this windshield?
Gears Saddle bags; I just got them, seem good so far, lots of straps , mounting options, expandable. Plastic panels back and U shaped for front, bottom back. The opening is a double zipper with a combined pull bar to operate both simultaneously, has velcro at rear and snap lock straps across the top to keep from overloading the zips. Bought at Performance Cycle in Madison WI $90, Also includes rain covers, probably best used as rain liners. Includes 6 straps with a sewn double loop on one end to aid mounting to bike. several cam locks sewn to bags to make quick work of cinching the straps. Two main top straps are held together with velcro for easy width adjustment and a third top strap between the two mains has a double d ring cinch (I ran the third strap under the seat.) the bags have elastic strap loops to store extra strap length.
I will prolly make (or find LOL) a couple aluminum straps to hang from rear fender mounts to keep bags from "tucking in" at rear. pretty much always a saddle bag issue. These do have a cross strap at front bottom which will probably keep that from happening. But this is a good place to use a belt AND suspenders.
currently mounted "throw over" style will prolly do an under seat mount also and compare
The shield here https://www.revzilla.com/motorcycle/national-cycle-street-shield-ex-windshield
Found gears mini saddle bags at Dennis Kirk similar or the same. https://www.denniskirk.com/gears/mi...m_medium=mini-saddle&utm_campaign=youtube_utm
