Finished dressing and prepping the frame ... its gone off for sandblasting as of this morning. My preferred plan for the moment is to paint rather than powdercoat the frame. Anyone care to offer pros and cons of each?
It's decades since I heard anyone mentioning stove enamel. Once upon a time it was the go to frame finish. Finding someone who knows how to do it might be an issue? But for sure, it's a lovely job done correctly.There might be further alternatives. Powder coating is a bit thick and gloopy, but I found a guy not far from here who did stove-enamelling. He did a great job with my TR6 frame, looked like paint but tough - he said you could hit it with a hammer, but I didn't try that out.
A relatively easy fab project made of materials at hand... quite a few turned parts, the the rest is just black pipe. As you can probably imagine, the strut that runs from the stem to the lower front engine mount lugs is essential. Otherwise, the frame just rotates around the stem clamp, no matter how tight it is.
Personally, I'm not a fan of powder coating a frame. It's difficult to repair, and an unseen chip can lead to large swaths of delamination thanks to rust propagation. For frames, I usually use Eastwood's Chassis Black Frame Paint. I find it easy to spray and very durable. It can also be repaired.
I've also had good luck using PJ1 Fast Black Epoxy Paint.
I do like powder coating smaller parts, however.
... I agree on all counts, which is why I have decided to go with paint for the big stuff and powder coat for the stuff that will see wear/contact, like pedals and stand etc.Agreed... paint it is.Checking in late, sorry. My opinion. Paint. Why, you might ask? Very little of the whole skeleton is ever in view. The front down tubes and the rear up tubes to the rear shock mounts. Only the front tubes are subject to stones, wear, pitting... With "one side" or high exhausts (scrambler or tracker) the lower rails are east to refinish/touch-up). I put this forth from the perspective of a guy who wants to have a decent looking rider...
That's what I was thinking...I have not done that in the past and I do have a second set of muscles ( Junior) to assist with the installation, so we'll see.lookin' good!!!
You gonna do the lay the frame on it's side method of install?
I built a rig to suspend the engine on a hoist, so that's prolly what I'll always use. If I had it to do over though, I wouldn't bother. From what I've seen and read, laying the engine and frame on it's side is the easiest/best way to go.I lay the engine on the floor on a 2X4 and 4x4 to create an angle, then put the frame over the engine and install the bottom bolt.
That's how I did my Beetle engine installs...just pick it up and put it in. Not sure that my back has ever forgiven me!I built a rig to suspend the engine on a hoist, so that's prolly what I'll always use. If I had it to do over though, I wouldn't bother. From what I've seen and read, laying the engine and frame on it's side is the easiest/best way to go.
In my youth, I just bear hugged 'em in and out.
At 72 now, I'd be hard pressed to bear hug a moped engine.![]()
