Project XS
She's a runner!!! Test fired tonight, minor mixture and idle speed adjustment and she sits there on the bench, idling away smooth and quiet. I'm stoked! Ready for installation in the frame. Got a few more brackets to clean and paint and hardware to prep, but otherwise ready to go.
Apart from completing the engine installation with all the brackets (that are still in paint), the next major step is to make this a roller. That brings me to the great swingarm dilemna; use a stock bronze-bushed swingarm, use the needle-bearing TX750 swingarm that's on the donor-bike or use the braced swingarm that @bosco659 sold me a while back. The TX750 swingarm has a TX wheel on it at the moment, with its comparatively massive rear brake/hub. Not a fan of that for this build, as the theme is light/slender/minimalist. Comments and opinions?
Braced swingarm. And I agree, you're thinking light, so a massive rear wheel/brake doesn't follow.
Right... so in the mock-up photos earlier on, that's an XT350 wheel which has a nice smallish drum and an equally nice alloy rim. I like the look but it will need some adapting to work on an XS650 swingarm. For example, it doesn't use a brake-stay, as it has a cast-in slot which is intended to fit over a square-section lug welded to the inside of the axle plate. We'll see...
XT500 or TT500 have a brake torque arm ,smallish rear drum and alloy 18" rim. A possibilty there.
I believe the issue with both my XT350 rear hub and the XT/TT/SR500 rear hubs is that they use a 17mm rear axle whereas the XS650 axle is 20mm. I'm looking into the possibility of a bearing swap to rectify that issue.
Also, if running electric start I would hook up the starter power cable before bolting it in. I am doing mine after the fact and I cannot get the nut off the starter post to put the cable on. Going to have to completely unbolt the motor and lift it a little to gain the clearance. But then again I think it is contacting the swingarm which could also be removed. It's been sitting that way quite a while and I cannot quite remember without looking at it.
Call me crazy, but there is a plan to resurrect this 1983 Special wreck.
View attachment 229461View attachment 229462
Why, you say? Reasonable question, given its state. I would like to build a "custom" but don't want to cut up or irreversibly modify my '77 XS D, so this is my blank canvas.
The Bad:
- seized, incomplete engine
- cut up wiring harness
- rusty to a degree, but not awful
The Good;
- chassis titled in my name
- have a complete/running engine
- have most if not all the parts to complete
In QC, a vehicle that has not been plated within the last 12 months needs to undergo an inspection. Modded bikes are frowned upon if not altogether uncertifiable. That said, the plan is to piece this together to the extent needed to pass an inspection. Once certified, it will get fully disassembled and built from a bare frame up. I will post as I go along, as I may need to encouragement along the way!
I don't blame you whatsoever for wanting to ressurect this bike. These machines were/are awesome to ride. I'm building a 1981 myself. I wasn't able to do anything with the factory carbs, so I bought a pair of Mikuni vm's. I'm still jetting on them, but I'm really close to having them the way I want them. Keep us posted with how it goes!!
Thanks for the comment...I checked the clearance/access based on your input and agree that it is tight at best. The engine is in but not fully bolted in so I'll make sure that I can get the starter power cable on before finalizing the installation.
Before you put the engine bolts in, just take the rear ones out again, tilt the motor forward a bit and shove the carbs on. Much easier than wrestling with em once it's all bolted up.
@Raymond, thanks for the comment. I think this is a very valid observation with the linked BS34's or 38's, but less so with the Mikuni VM34's that are going to be used, as they are independent of one another. On my 650SG, I have removed and reinstalled VM34's several times without having any issues.
I replaced my factory carbs with the Mikuni vm's, and am outright amazed at the performance difference. I ended up using number 180's on the mains, and 27.5's on the pilots. The difference is hard to describe- this machine literally LEAPS when you crack the throttle, and the difference in top end pulling power is amazing as well. It starts right up with the crank start or the electric start. I would advise anybody who is interested to do away with the factory vacuum pod carbs, as they seem to really choke these machines down. I really wish that I had a Dyno so that I could have checked it before and after the swap to measure exactly how much performance I gained, not to mention the overall rideability quality. You won't regret doing this!!!
I like the VM's for their cable-operated round slide/needle, rather than the BS34/38 vacuum-controlled slide/needle. IMO, a large part of what we feel as improved performance is in fact improved responsiveness.
'Zackly. Other than responsiveness, the vacuum BS' will perform just as well... and much better with large altitude changes.
A big increase in performance switching to VM's means the original carbs most likely weren't tuned properly.
If you're gonna use a scrambler as a scrambler, then yeah, the better throttle response of the VM's is the way to go. The last thing you want on jumps is throttle lag.
Agree 100% Have had mine on my xs for10 years . Starts cold real well on the button. when warm it's almost always a one kick bike . Throttle response is
greatly improved.
