Well that'll be a while........
Project update. I'm still in that going backwards, more issues cropping up stage, but
hoping I've rounded the corner.
The easy project was the tool box door lock. Some aluminum rivets from China, a bit of begging from my neighbor the locksmith, he rebuilt, re-keyed the lock, a little fab on a 16P nail to replace a missing hinge pin, and done.
Then the head cylinder saga continued.
The head with a dropped valve seat head went to be rebuilt.
Lapped the valves on the "good head"
View attachment 348631View attachment 348632
then decided to pull off the cylinders and see how they looked, was thinking make sure the rings were free, new gaskets and done.. HAH!
View attachment 348630 View attachment 348629
So pulled the side with the dropped valve seat, that looked great, go figure.
But the rings were SERIOUSLY stuck, busted the oil ring trying to get it freed up.
So My local Mr. motor did a light hone, vapor blasted the outsides, and jugs will be fine.
View attachment 348636 View attachment 348637
A new set of standard size pistons and rings ordered. WTH sent the
other head that I did the valve lap off for an overhaul too. the hive had been warning do em both, I finally caved, in for a penny, in for a pound.
The oil pan was making a puddle, so that came off and got massaged last night. Primitive Pete had really reefed down the bolts to stop a weeping gasket, that never goes well.
View attachment 348635 View attachment 348634
I'll find or make some washers to spread the bolt loading to avoid re-warping the steel pan. then some Hylomar blue on the new gasket and back on.
Doing all this to get the Beemer off the lift for a bit so I can put the TX650 on it and see if it will be the ride for the Slimy Crud and maybe the Ozarks rally. Those efforts will be detailed elsewhere.
