LeftyKash
Last week on my way back from AMA Vintage Days I pulled into a gas station, hit my kill switch, turned off the bike and filled up t he tank.
After gassing up the bike would turn over, but it wouldn't even try to start. The voltmeter off the key switch showed more or less 12v. I didn't have much for tools, but I took the kill switch out of the circuit, thinking maybe it had gone bad. No dice. I had recently switched to a gonzo TCI, as my OEM one was cutting out intermittently. Since the old one was still on the bike, I plugged it in. The engine tried to start, ran really rough, but wouldn't idle or rev up at all. I gave up and called a buddy with a truck to come get me.
Once I got home, I checked the plugs, they looked ok. Plugged in my spark checker, no spark.
Checked resistance on my coil secondary ~24k ohms ok.
Checked resistance on coil primary 2.8ohms OK,
Checked the pickup coil, 750 ohms on each side, 1500 ohms between them. OK.
On a whim, I opened up the LH cover, and found that the magnet that the PO had put on the rotor had given up the ghost.
I'm not 100% convinced that it is the only issue, but once I wash all the Vintage Days dirt and mud off the bike, I'll pull the rotor and repair.
It was a hot weekend and I'd been riding the bike a lot. It ran perfectly all the way to the gas station. I'm guessing that once I stopped to gas up after that long ride, the adhesive picked up just enough heat to let go. Who knows for sure though?
