Superdriver
I have a 1978 XS650 with a 19 inch wheel conversion kit from Omars I have a stock 19 inch wire front mounted on the rear. I would like to know if I can mount a stock SR 500 5 mm disc on the rear hub so I can use a Brembo Caliper which from what I've read, can accommodate up to 5mm thickness. I would appreciate any help or suggestions as far as other discs I could use. Also, if anyone has any ideas which Basic Brembo Caliper would work, it would be appreciated Thanks. Bill
