• 🎁 Enter the September XS650Direct gift card giveaway! It's easy... Click here, post something, and you're entered into the drawing!
Rear wheel clicking noise
bwe421
Milwaukee
hey all! I got my wheels powder coated and also new brake shoes for the rear wheel. When installed and spinning the wheel, I hear a clicking noise. It's def coming from the brake drum. I THINK its the blue circled parts of the drum hitting the red circled part of the hub. Anyone ever encounter this? recommended solutions? Brakes are from Mike's
Thanks in advance!
If you want to know for sure, use some Prussian Blue on either the red part or the blue part (not both) and reinstall and give a spin.
If there's any metal to metal contact you'll know when you disassemble again to check for transfer.
Could it possibly be this part? It seems to be sticking out much further judging by the shadowing
Also looks like the cam is backwards/180 deg out. See how two opposite edges have a more gradual radius? That's so you don't get "all or nothing" when you apply the brake. Makes it more gradual... or linear if you will.
That gentle radius is what should contact the shoes when you turn it to apply the brakes.
Whoa, I’m kinda confused but curious.
It does look like the arcs are different on the faces of the cam, but are these two arcs highlighted in blue of different geometry?
Check the outside flat surface at the end of the splined shaft...there should be a little dot offset from the center, and the dot should be on the side closest to the axle (the inside if you will), not away from the axle or on the outside - see pic.
Check the outside flat surface at the end of the splined shaft...there should be a little dot offset from the center, and the dot should be on the side closest to the axle (the inside of you will), not away from the axle or on the outside - see pic.
I knew there was a way to tell... :umm:
...jus' couldn't recall how. :doh:
i never took the cam shaft out of the drum and the "dot" is facing away from the axle. do i need to take out and rotate? everything seems to be working as intended
@Kevin Werner i see you're in Sheboygan. Nice! I am in Mequon
Yes. The cam is ground so that it pushes more on one shoe than the other (don't remember which).
If it's backwards, the brakes will either be weak or grabby on initial application.
