Rear wheel - What year and model??
Yes that’s my solution I hope to go with a rear drum set up with 36 spoke hub. If I need to get the plate no worries as long as it lol bolts up to the 83 swing arm with brake bar etc.
Someone stated that any year XS650 36 spoke drum would fit. Would I use existing plate or need one to fit the 36 spoke hub?
The one you have will work. Generally - but maybe not in every case precisely/exactly - the plates are interchangeable, only some having "features" that have come and gone e.g. brake pad wear sensor.
Close is oak with me no need for sensors and wear checks etc. long as it brakes and spins! Or fall off 😱
I found this set for 300.00 both front and rear from a 76 XS. My question would be will my front disk bolt on that wheel?
That way I have 36 spoke front and rear
Edit:
    • The Fix: If you bolt the 1976 wheel onto your 1983 bike, you will need to swap your 1983 brake rotor (or a compatible later rotor) onto the 1976 wheel hub so it aligns properly with your 1983 brake caliper.
    • Edit: My current 83 rotor would fit according to AI? *coughs
Edit:
    So a 76 rotor would do the trick?
Not sure. While the bolt hole pattern is the same, the earlier brake discs were 2-piece, while the later ones were 1-piece. Also, fork tube diameter changed 76 -> 77 from 34mm to 35 mm, which would alter disc offset (I think). But...
There are others on this forum that know these details way, way better than I - @5twins , @gggGary ?
Ok thanks man you have been a great help. Hopefully they will chime in. That quote was from AI so I’m bit skeptical as well.
I would be inclined to think this is true: "you will need to swap your 1983 brake rotor (or a compatible later rotor) onto the 1976 wheel hub so it aligns properly with your 1983 brake caliper."
I would be fairly certain it will not work with the '76 disc.
Ok...front hub p/n appears to be the same - 341-25111-01-00 - for 76 and later hub (e.g. 78) i.e. hub the same for later 34mm forks and 2-piece disc vs the transition to 35mm forks, etc. So, pending other (better) knowledge, etc. you are probably good to go.
In other words, use the new hub with all your other 83 hardware and it should bolt up.
BTW, since you are changing rims anyway, you might consider going up to 2.75" or 3.00" in the rear, and even up sizing the front to 2.50. Some even run 3.50"r & 3.00"f. There are handling benefits to be had with the wider rims and modern tires.
That’s great news!
I’m wanting to go wider for the street tracker style. Front fender removed and rear as well.
Width was a concern so I felt 2.15 was max on the rim. Looking at the rear currently is 2.15 with a 4.00 tire and it’s close plus moving up to a 19 inch rim in the back.
Definitely going to 2.15 up front but try and keep same for the rear or at least not wider.
Tires will be Dunlop K180 flat track tread not the best for road even worse for the track however it’s a DOT rated flat track tread.
However I have to pay attention to the K180 sizes as can be tricky even if size is made it might not be available.
Ya just checked the rear. 130/90 street tire on 2.15 rim and it’s maxed imo.
Very little clearance
There are a lot of variables in play. I recall your bike is a Special, and if so would have a 16" rear wheel. You might want to double-check, as most of the 16" rear wheels are 3.00" in width?
As an example, my '78 650E has a 18"x3.00" rear wheel with a 120/90-18 Bridgestone Battlax BT46 and clearance is comfortable. And if there were issues, it would likely not be the swingarm but would be the chain guard, the shocks, or the brake stay.
I have also found that, while rim width helps handling, it often doesn't affect tire installed width much, as the narrower rims often cause the tire sidewalls to bulge.
Finally, I have found the biggest variable is the actual tires, as the same size from two different manufacturers can vary significantly. As an example, on another bike I have, it has a 130/90-16 Avon Roadrider MkII mounted on a 3.00" rim and the sucker's mounted width is almost 6"! This caused me all sorts of pain and gymnastics with chain guard, shocks, etc.
Best of luck!
Best of luck!
Ya It’s always something lol
I made the deal on the two wheels 300 for both includes all hardware. I can always clean up the rims and resale.
I’ll probably keep it at 2.15 the K180 tread may make a play in all that.
Best of luck!
The stock rear rim size for the 1983 Yamaha XS650 Heritage Special is 2.15 x 16 inches (48-spoke alloy/steel rim).[1]
Thanks, didn't know. 2.15" seems very narrow for a 130 (or originally a 5.00/5.10) tire; most that I was familiar with were 16" x 3.00".
Ya I forgot it was a 5.00 even said it was a 4.00. Very little clearance on the swing arm but everything else is good.
Tires looks small too strangely and only K180’s one can find is the 130.90 rear but they fit according to AI.
Yes the front wheel from any year after 72 will fit, use your late model (77 up) rotor.
I also agree that 11090 is widest recommended rear tire for a 2.15 rim go beyond that and handling at high levels of riding may suffer.
This is old;
but so are our bikes ;)
Will take that into consideration. A lot will depend on what size is available from Dunlop K180’s. Currently a 130/90 is on the bike so as fitting goes it should work. The bike will not be driven hard or even at high rate of speed. 70 mph max if that but mostly around town when I get the urge. I have my Honda for any hard rides. I mean this XS is 43 years old so will be easy on the old gal.
