Rear wheel - What year and model??
Looks like the Dunlop K180 is available in very limited sizes.
Yes, this is true. One has to look hard to find them. I have found 130/90 x 19 but it will be a while before I’m ready so who knows. 19 inches helps once you go lower this is where the hard part comes in. 18 inches are around tho but limited.
All righty then! 🧐
After further review and removing the mental block for 2.15 x 19 width rims. I found suitable 2.50 rims to mount on the 1976 XS650 hubs, both front and rear. I also removed the mental block for the K180’s and now going for Shinko SR267 130/80 x 19 both front and rear.
This project is driving me bat **** crazy 🤪
Edit:
Stand by folks the rims will not work. Apparently the Yamaha hubs will not fit the 2.50 width unless a blank is custom drilled and custom spokes cut.
Anyways I made inquiry to have the blanks drilled and spokes. Cost most likely are out of my range. Hope springs eternal tho
I may just have to go with 2.15 width and hope the pinch will be acceptable. Currently there is a 130/90 street tire mounted but no room for any more.
All righty then! 🧐
Edit:
View attachment 379014 View attachment 379015
I don’t like the pinch. Even if it works, I don’t like the way it looks.
Interesting…
What to Expect When Riding
    • Grip & Handling: Squeezing the 130/80 tire onto a 2.15" rim is a very common custom setup for flat-track or street-tracker conversion builds utilizing stock dirt bike wheels. It forces the tread into a steep, rounded crown, which provides predictable cornering feedback and plenty of lean-angle side grip on dirt ovals. [1]
Interesting…
And thank you again, AI!😊
Beauty is in the eye of the beholder.
Not a street tracker fan or?
The pressure is low, but it’s a 130/90-17 on a narrow rim. (XS1100)
This is a 130/90-16 on a wider wheel. I’m much more comfortable with it.
The narrow 17” wheel was made for a tire no longer available.
Nope! I have nothing against trackers or your intention with the wheel/tire combo. It was just an expression of my opinion.
Ahhh ok that’s much better! 🙂
I like different opinions and why I was wondering where you were coming from. I love the 2.50 rims better but man o man the cost! I asked for a quote but geez! Will wait to see what I hear back.
That Italian rim pictured I just love that old style and thought 135.00 was a fair price. Then went back and it’s 119.00 shipping plus tariffs from Italy x2 500 bucs for rims! Then spokes add lace up cost then tires and tubes gawd! 2 grand for wheels?
It’s a rabbit hole for sure and I’m falling fast lol
Thanks for your input!
Sheer madness!
The way it’s going is I will need to go with 18 inch rear rim. Not getting any results having custom cut spokes.
Doing that means back to K180’s :umm:
Will save money too!
I messaged them yesterday for Excel rims or a recommendation. There seems to be a snag on spoke angle for the xs hub.
Still waiting for a reply. Not sure if you spoke to them or just checking out the site?
Using a 36h rim apparently is not enough to match.
Checking out the site. I got my rims and spokes from them, Excel rims, SS spokes, 19x2.15F & 18x3.00R 36 spoke, disc front, drum rear 78E. Seems weird though, they make the spokes aso, so it seems like they could make some to fit!
Edit: Thinking more about it, I used dimpleless Excel rims, so maybe they could just drill them, angle, etc., in a way that was required?
Checking out the site. I got my rims and spokes from them, 19x2.15F & 18x3.00R 36 spoke, disc front, drum rear 78E. Seems weird though, they make the spokes aso, so it seems like they could make some to fit!
Yes, the 18 inch rear would work as the angle is correct, this is what one vender stated;
“However, we do not offer a spoke kit for the 19" wheel on the rear. Yamaha never put a 19" rear wheel on, so those spokes will most likely have to be custom made“. So, it’s the spokes that have to be cut and bent to the proper angle to work I suppose.
They do offer from this vender the 18 inch set up for the rear so most likely you found that rim set up. Yamaha did use 18 inch rims somewhere.
Also why I’m considering dropping to 18 inches. Still waiting to hear back tho. I prefer the 19 and the Shinko tires however they do not offer 18 inches. Like I said sheer madness lol
It's like every project, every build, on every bike, once you start changing $hit, all bets are off!
lol
Yes sir!
That’s the way it goes and as much frustration it is, we keep going!
I pick up my hubs tomorrow that’s 300. Seat pan was 74.00, seat and cowl was 217.00, shocks 416.00
Tracker bars 59.00, grips 19.00, new master cylinder 37.00, tons of other stuff, oil sump filter, crush washers for drain plug and sump filter. LED lights shy of 100.00 and new impact sockets, new low torque wrench, JIS screwdrivers and the beat goes on…
lol
Yes sir!
Ha ha😂. I don't keep track because I know I will have much, much more invested in the bike than it is ever going to be worth...and that's just the parts cost, the labor - of course - is gratis. So it's irrelevant, and clearly not why we all do it! As an example, I have a nice '78 650E that "might' be worth $4K to somebody else on a good day. And I can guarantee I have at least 2.5x that cost in the bike. Again, who cares?!😎
It’s like we can’t take it with us! And it’s therapy I keep telling my self! To get up and go to my garage and piddle brings meaning and exercise! Not mention all the brain puzzles 🤪
It will get sorted…one day!
Our bikes are an extension of our being, personality and we like showing them off too 😎
Definitely going with 2.15x18 in the rear with a Dunlop K180 120/80 tire. Absolutely no fitting issues. The 19 inch solution would amount to 700.00 laced per wheel Excel rims however imo would need custom swing arm.
Way out of my budget that’s 2000.00 all said and done.
I can even clean up the rear Takasago rim from the hubs I’m getting today and just re-spoke it.
Most likely I’ll end up getting new rims and Dunlop K180 tires. 100/90 x 19 front and 120/80x18 rear(very tight fit)
Sounds good. I have 120/90-18 on a 3.00" rim and fits no problem, so you should be fine.
UPDATE:
Brake hub is in spec! Great news and finally something going my way! Will the tide turn? Stay tuned folks!
A wise man once said it’s “better to spend 20 dolla on caliper to measure 181mm than to lace wheel with out of spec hub”
Rim sizes:
Rear will now be 2.50 x18 with Dunlop K180 120/90x18 tire
Front 2:15 x 19 with Dunlop K180 100/90 x19 tire
Edit: changed 80 to 90 on the rear tire
