Okily dokily.
I reckon this one could be a record breaker.
Not charging. XS650SH 81, but it’s the Australian one so it’s running on points. Oh yeah and separate mechanical regulator and rectifier. It’s as stock as possible. Have read loads, tested loads so let me give you a breakdown.
Battery good. Deka AGM.
Brushes exceed recommended length.
Rotor tests good across the rings.
Regulator tests good according to the Haynes manual across brown green and red wires. Correct resistances.
Was stupid enough to take it to a classic bike mechanic for the first time in 20 years ownership to get some diagnostics. Was told it was the rectifier. $280 later. Claimed to have tested the stator and said it was good.
New rectifier fitted by me- no change except for the weight of the wallet.
Going for the record on replacement parts now so….. replaced the loom with a genuine NOS original beauty. Cleaned all contacts on plugs during install and whilst there replaced coils ( not done on original rebuild 15 years ago. )
Oh by the way it runs beautifully right now off the battery. Best ever in fact due to nailing the timing in another thread.
Question: Should there be a small magnetic pull to the rotor when bike is off?…. Seems to suggest a leakage of current somewhere. This magnetic force increases when key on but is not strong enough to give a positive slap test.
was producing 12.5 volts at the battery before new loom now gets to 13 but that’s with the regulator cranked up to max.
Did not touch the earth straps or battery cables. Checked / inspected the earth and it looks very good.
Ok so what would you like to know or see?
I checked setup of brushes and brush holders tonight.
Maybe after all the work it just needs a ride in?…….? Can’t ride it till new air filters arrive. Must have been degreaser which eats them. ( Lesson learnt there.)
I have to rev up to around 4 K and hold it there for the voltage to slowly tick up. Eventually getting to the 13 Volts across the battery.
Happy to be called a dummy on any point at all. Happy to keep learning till they nail the lid on….
Thanks so much in advance.
