I've never used heat, and I think it is a bad idea for the reason you asked about.
I use two pairs of needle-nose pliers, and a lot of fumbling around is involved. Try bending a new hook first, as close as possible to the original hook, then cut off the original hook. The new hook does not need to be well-shaped -- just anything that will fit in the hole in the advance weight. And it doesn't have to be oriented like the original hook was.
