Replacement Carb Intake Manifold Boots for BS34
Gowron650
Pennsylvania, United States
I am trying to find replacement carb boots for my '83 XS650 Heritage Special. I have bought two sets of replacements on ebay, but neither will fit properly.
The OEM carb boots have a lip that is about 4mm from the edge, which matches the lip around the outlet of the BS34 carb. The two aftermarket pairs I have purchased so far have a lip that is ~8mm from the inside edge, which doesn't fit. Even using a little grease and a heat gun and forcing them on there, they just pop right back off.
I have attached a picture for reference.
Does anyone know a reliable supplier of replacement boots that is still in operation? MikesXS is sold out of these unfortunately.
Where'd you get them from? I just got a set from CruzinImage in Japan but haven't teet for them yet. I'll try tomorrow and let you know.
I bought mine from Cruizinimage and although tight, seem to work great. Cruizinimage is fast and good.
@Gowron650
Did you find a set that works well? I'm at the same point in my project and the set I bought from Mikes XS have the same problem You mentioned. The molded rib is not in the right spot and they don't sit flush/flat when I force them onto the carb. I figured Mikes XS was the place to get them and I wasted $50.
@Gowron650
Yes following the advice on this thread I found a pair marked “ARS.”
You might be able to find something cheaper but this is what I bought:
https://japan.webike.net/products/23198374.html
@Gowron650
Send them back. My new GoTo strategy for crappy parts…
Looking for new intake boots for a '81 XS650H. Not having luck finding Tourmax boots. Looks like JBM has angled BS34 boots. yamahaxs650 also advertising boots with proper groove depth. Anyone have experience with the ones from yamahaXS650.com?
