Kansas City, Mo.
There was an XS250* and its bored-out brother, the XS400.
I'd not be surprised if there was a sleeved-down XS200 in some market.
* I had one as a stand-by bike. Scary stuff, on the motorway, as it lacked much in the way of grunt.
Ok as a back roads get-you-around type of bike, but not for motorways.
https://www.motorcyclespecs.co.za/bikes/Yamaha12.html
Say the word and I write you name on one... :whistle:
Hey Jim, this is Tim from Toronto Canada. I have a rotor on my 77 XS 650 with showing a reading of four ohms and a maximum charging voltage of 13.5. I think I may need a rewinding or a replacement rotor. I have read your article for May 15, 2019 and was wondering if you would be able to help me out?
Tim this is John in Victoria BC. Buy the new rotor and don't worry, be 😊
I think I should buy another one from Jim just cause they look cool and maybe I'll get another XS?
The batch of 8 I rewound back in June only lasted a little over week before they were gone. Unfortunately, only 3 cores made their way back to me. :(
Had a couple needed doing for a forum member, so I went ahead and did a couple more while I was tooled up.
These are the old style. Will work on any year, as long as you are not running the factory TCI. Details in comment #1
That's a shame people don't respect a good service. Even if you charge a bit more for a non replacement rotor it will end up causing you to run out of factory rotors.
This will affect the supply of XS650 rotors for your service
Might have to receive a rotor before sending out a rewind if the buyers have one. Or is the lack of returns because they didn't have one in the first place?
Pretty much, yeah. That or they just want a spare (extra one) for just in case. No worries, once the cores are gone, it'll just be a rewind your rotor offering, no outright sales.
Worst case, someone can buy a junk one off Ebay and send that to me. :shrug:
Hi Jim,
I’m in need of your services. Do you have an already rebuilt one on hand? I’d prefer to buy it, rent the puller and return my core and the puller all in one pass. if not I guess i’ll get mine pulled and sent off to you. please let me know how to proceed.
Hello Jim, Pretty sure I need a rewind, just wanted to check on some testing details. My 78 standard all stock
with 7700 miles barely puts out 12volts at 3k. Brushes etc.. seem ok but I get 1.3 ohms across stator windings.
Magnetic field seems weak but is there. I get 9.6 volts at positive rotor brush key on but increases
to battery voltage with wire unhooked from brush. Battery volts resting 12.65 and 12.3 key on. Volt drop
through regulator with rotor load or is that normal?
Thanks.
Bill
First, welcome to the forum!!
If you're referring to the stator windings, that's too high. Should be about a half an Ω leg to leg.
If you're referring to the rotor winding, it's too low. Should be about 5Ω.
Remember, rotors rotate, stators are stationary. Which are we referring to?
The rotor, Spinning part for sure. I had a brain oops. I guess my question is will
low resistance across rotor windings cause a drop in voltage seen at positive
brush? This is with everything connected and key on engine off. I see about
9.5 volts but if I remove wire from brush I get battery voltage at wire.
Sure looks that way, I need to order some parts from one of the vendors on here and will include a rotor puller
in that order. Anything specific to look for that would cause rotor insulation failure? It does not look like
it overheated, no burnt smell. At one point this bike had hard bags with extra tail lights and a vetter
style front fairing with extra running lights. Maybe extra load over time? I plan on going over all parts
of circuit anyway, just looking for likely culprits.
