Will77
Ok got a 79 xs650 runs good down highway but when taking off will miss and only run on left cylinder then comes out of it and will occasionally back fire out of right cylinder when decelerating from high rpm checked float hight 28 mm both carbs same checked for vacuum leaks none and I have to have the adjuster screw out 6 turns and it runs ok but not great on right cylinder I also bench synced the carbs and when I hook up vacuum gauge to ether cylinder it flutters between 0 and 20 good compression on both cylinders to I’m at a loss please help thanks
