There are certain places where you can be quite liberal with sealant. On your photo which follows I have circled in yellow some spots where you can get annoying slow oil leaks. Its OK to be liberal here because when you torque down the rocker cover you can stick your finger in side and wipe off the excess that squeezes out. Where you have the labels 1,2,3 and 4 I apply a little extra sealant but position the bulk of it more towards the outer edges so the tendency is for the excess to squeeze out rather than in.
As to which sealant to use, I use RTV Red, but many disagree with my choice and prefer the Permatex types or Hylomar Blue. I think Hylomar Blue might be trending as the more popular choice now??? Years ago I always used that varnish type that came in a small glass bottle with a little application mop, but you had to work fast with it. Its all personal choice and you probably have your own favorite, just try to avoid too much getting squeezed inside where the oil is.
Was this vapor blasting that gave you such a nice clean rocker cover? What other modifications/upgrades have you included in your build? I am sure many will be keen to see how your engine and bike progress so please update this thread from time to time if possible.
Good luck.
