Hello all
I bought my 1981 Special four years ago, but I have only recently gotten it approved for the roads. There are several things that need to be fixed still. At least now I can test drive it when I've made changes.
That brings me to the issue; well.. maybe it's not an issue. The engine runs fine I think. It is equipped with two BS34 carbs with what I think is stock jetting: #42.5, #132.5 and a #130 pilot air jet. I've put on UNI foam filters. The ones where the ends are closed off with plastic or PU. The exhaust system consists of two separate single walled headers with megaphone mufflers. It's those aftermarket ones. Not very large and with a reflective insert. I've padded them slightly, but they are quite open.
I would expect to have to change the jetting to a richer mix, but as it is now, I have the idle mix screws turned a quarter of a turn out on both sides. If I back them out further, the idle rpm drops. If I turn them all the way in, the rpm goes up. I guess the idle mixture must be rich. I just can figure out why. I did not expect to have to install smaller than stock jets. I have a feeling that I'm missing something. I do use enrichment, when I start up, but only at the very start. If I pull the knob out later the engine stumbles and almost dies.
What else can I say about my setup..
I haven't synchronized the carbs properly. Only roughly with my eyes on the bypass holes. Ignition timing flutters a bit due to a worn ATU, but it runs reasonably well. Oh.. and I'm just now remembering that I sometimes see a drop of fuel on the edge of the bell on the right hand side carb, when I remove the filter. I had both carbs off a couple of days ago and the intake boots were a bit wet. I don't know if that's bad.
Any ideas to what I may be missing here?
Thanks..
Thanks..
