A stock spacer measured 90.8 mm, 3.57 inches.
You could just shorten up the spacers you have.
What a shame you're not restoring a XS1B !Minor progress as I patiently collect a few more parts. A few weeks ago I scored the used set of factory shocks from Halfmile posted above. The patina fits the rest of the bike and they are a fair nick better than the ones I had. I also acquired a set of side covers and headlight assembly (ears, bucket, light and trim ring) here in the classifieds. I’ve been watching for a useable left cover for some time and everything I was seeing was fairly rough or ridiculously expensive. These units came off a gold xs1b but were crudely spray painted an awful purple with white pinstripes.
View attachment 330531View attachment 330532View attachment 330533
Today I spent about 45 minutes stripping the purple off one cover. Just a bit of brake cleaner and a plastic scraper effectively removed the old paint. Jim gave me a few tips that helped. I worked in small areas and gave the paint time to harden back up between applications. Although I’m not sure this process is necessary as there is some rust that will need addressed before painting. But I am extremely pleased with how straight the covers are. I’ll mess with paint once I have it running. For now I’m just pleased to have the missing parts in hand.
If there is one thing I dislike about messing with these bikes it’s the old varnish smell from carbs and tanks. Maybe because it’s just so hard to shake it.My hands smelled of varnish for a few days
Why does fresh gasoline smell good and old gasoline smell so bad?If there is one thing I dislike about messing with these bikes it’s the old varnish smell from carbs and tanks. Maybe because it’s just so hard to shake it.
It’s repulsive like rotting meat!IT RANKS RIGHT UP THERE WITH THE SMELL OF OLD FORK OIL!
Not quite as bad as burnt differential oil though.If there is one thing I dislike about messing with these bikes it’s the old varnish smell from carbs and tanks. Maybe because it’s just so hard to shake it.
