Seeking Advice on Comfort Mods for XS650
I know it doesn't seem like much (150 RPMs) but a 33T sprocket is sweet on an 18" wheel. It's what Yamaha put on the European models and is very well matched to this motor's power output. Go any smaller and the take-off power in the lower gears takes a pretty big hit. I tried a 32T and didn't like it because of that. On the other hand, I find a 32T is ideal on a 16" wheel. Final gearing is just slightly higher than the 33T on an 18" wheel, but not enough to hurt the take-off power ......
I will definitely try it out. For now will keep the curren gearing since I am not done torturing this bike on the dyno :)
My airhawk goes on many bikes when a long ride is planned.
Very little air in it. Always less than you start with. Just enough to relieve pressure on the sit bones
Also, try a sheepskin on top of the Airhawk. It allows air to pass under your butt reducing or eliminating monkey butt and keeping your pants dry. I buy mine from Ultimate Sheepskin in Washington state.
That's all I use. I tried a gel pad that also took air, and the top was fake sheepskin. Not so good. Anything more than a small breath of air in it had you sitting on a big bubble, lol, and it leaked out anyway after a while. So, I mostly used it with no air. Then I got a real piece of sheepskin with one of my bikes, and that became my "go to". Boy, I'm glad I didn't have to buy it, those things are expensive.
did you consider 40mm lower?
Yeah a custom built solution would be best but it's not high on the round tuit list.
Rode madness at the rally and noticed later how comfortable I had been riding. I'm starting to squirm at 150 (or less) on many bikes.
Hand position still isn't perfect but it's not FAR off. For true long distance runs I tend towards the cruiser position. with a back rest.
i was referring to adjustable peg coming in two options seems like: 25mm and 40mm
Another observation I made is that the XS has pegs significantly more forward compared to other bikes that i considered rather comfortable: GS1150 and Buell M2. It seems that there is something to it. Here is a post on a Triumph group: https://newbonnevilleriders.com/forum/threads/bonneville-foot-peg-lowering.6061/#post-111348; Or this: https://tro.bike/motorcycle-touring/triangle/
I am starting to think that getting some of these footpegs and rotating them backwards and down a bit may be the way to go. As long as the shifter and the rear brake can still be operated. Has anyone experimented with something like this? How well do rearsets work on XS?
You probably will need to drill the end of the pivot pin to get it out as it's "riveted" ......
The above two pics are of XS1100 pegs but the 650's are attached the same way. For re-mounting the new pegs, you may consider a clevis pin instead of a bolt. The XS850 used these .....
Yamaha still sells both of these pins but it would be much cheaper just to buy a bag of clevis pins of the proper size.
The price of original footpeg rubbers has gone way up (to around $40 each). Seeing as how I wouldn't pay the $24 asking price from a few years ago, you know I'd never fork over $40 for one, lol. The aftermarket ones are junk, wearing "bald" in just a year or two, so I watch eBay for deals. I managed to score 3 N.O.S. XS1100 footpeg assemblies about a year ago for only $12 each. I'm going to try to press the pins out on my hydraulic press, maybe I can save them for re-use. But if not, I already have a bag of clevis pins to use, lol.
awesome! thanks. Yes, the pins seem to be pressed in
Will follow along and will be interested in your peg moving experiments.
Foot location is very "individual" At 6'3" and 35 inseam my ideal may vary from yours.
Honestly I think Madness may be the first time in many XS650s that I've moved the stock peg location. These foot rests had been chromed long before my ownership so were already assembled with other than stock hardware.
:twocents: Going from a foot PEG to a foot Rest is probably a big part of the comfort improvement. I've done that on several of my long distance MCs. A rubber insert that's flex mounted to the bracket helps too. The broader support reduces ankle fatigue.
silligrips or some other grip protrusion that allows relaxed finger grip
I can't seem to find anything that looks like the grips on that bike. I have the special pull backs, I love em for cruising i have a bar across front frame for highway pegs to stretch at times, so in my case the virago risers would be overkill. I know the buckhorns aren't popular idky for cruising, i tried euro or Honda cb from mikes years ago, the specials let me sit back stretch my arms and ride.
Anyway I'm looking for leeds on grips not bars. Lol
Anyone have good grip recommendations. I had a cheap generic set I swear they caused me to wipe out, on a damp turn off my block I wound up on the ground spinning, the ends cut through and rubbed and got held up on my switch gear. Keep that in mind, it will never happen to me again.
nice subject! I find this intereseting as well. I changed my pegs from OEM to a mix between mid- en rear pegs. Im not a fan of the original peg position because your feet are quite far forward. Making it to easy for my lower back to bulge a bit.
However ive come to realize that moving the pegs Can help! but now it makes the angle of the knees sharper. Its all related, seatheigth, handlebar, pegs.
I rode this for seven hours with no difficulty. It is fitted with 8” mini apes and I was sitting on an Airhawk. My plan was 12 days in the saddle which I believe I would have accomplished no problem if not for an internal engine issue. I am tall and age 66. I rode that way highway, dirt and gravel. It works for me. YMMV
