OK. I got three heat cycles on it, then retorqued the head. In addition to the base gasket leaking, the six bolts on the cam chain tensioner were loose. Doh! I drove it about 35 miles. It's very smooth and quiet. I washed it and put it on the lift with paper under it. I hope I'm done with leaks for a while.
I had take one of the carburetors all the way down. The shaft was binding even with the butterfly disk removed. I can't imagine how that happened.
This started when I broke a bolt on the sump plate. I had to split the case to fix that, so I replaced my transmission. Then it got clutch springs, piston rings, and the head was serviced by a machine shop in Memphis. I have brake lines to replace, so I'll get on that as soon as I'm satisfied the engine isn't coming back out. My swingarm bushings are worn out as well. Those bronze bushings I bought from Mike's XS only lasted about 20 years or so.
So, I'm not done, but getting close. I'll try to get a few miles on it over the next couple weeks and torque the head again.
