Turn1nitro24
I'm looking for a Yamaha xs650 specialist in my area. Orange County Ca. I need help diagnosing some issues that could be (IMO) 1 of 2 things. Timing - points Ignition or VM 34s. Bike runs good 1/2 to full throttle pulls. Rich, but runs decent. However the bike will not run or idle below 3/8 throttle. I've tried everything I know. I'd love to have a second opinion on the situation. Compression 145-150 on both cylinders. Fresh rings and top end rebuild. Valve adjusted properly, cam timing is correct- checked it twice! New points/condenser and coil. Starts "kick only" relatively easy, but will not idle. Appears to be running rich as plugs are "suitty" dry black. not oily. MJ-170, pilot-12.5, needle on 2nd to top clip position, 2.0 slides, 1 1/2 turns out on air screw. I can set the slide screw all the way in and she wont idle. Any help on the situation is greatly appreciated.
