So it begins.....
Jan_P
XS650 Guru
Sweden
Last time I got it wrong i switched the 2 leads going to the magnetic pickup
those please check
Jan_P
XS650 Guru
Sweden
So your telling me that even though the white tracer and yellow tracer are labeled to go to one another, switch them? Because as it stand yellow is to yellow and white tracer is to white tracer
No if the colors match it is connected right please check upstream
As
Enclosing the instruction blue box there the wiring can be seen please check if the same
No spark as in nothing with the plug outside or no ignition ¨with plugs inside
  • KIT00303.pdf
sweatybetty89
morehead ky
As
No spark when grounded to the head or in the motor its not firing. When checking for where I got power it's all the way down to the coil.
Jan_P
XS650 Guru
Sweden
OK If you have power + 12 V to the coil
Please check 12 V to the box ( Red )
Then the white must have a solid ground .. I have mine drawn all the way to battery minus .
Please ensure ground for ( white ) ---or better draw the ground ( white ) to battery minus for testing
Jan_P
XS650 Guru
Sweden
Going to bed its late here if you don't get it to run I recommend disconnect the battery so power is not on the system
It can be a risk should something not be connected right
I check in tomorrow
Jim
XS650.com Supporter
Kansas City Mo.
Correct. That's main power to the whole system.
Jan_P
XS650 Guru
Sweden
I got 2 bullet connectors plugged into ignition lead(red white tracer) one goes to box one goes coil
Strictly speaking it should be one Red and one White Red
please look above
As long as you have 12 V on both coil and box + and white to ground it will ( or should ) fire
sweatybetty89
morehead ky
Here is what I got
Jan_P
XS650 Guru
Sweden
Here is what I got
Cant see exactly ..but with the wiring in # 88
There should now be 12 V on Coil and Box
black between coil and box not possible to connect the rest wrong
If it does not fire now the ground the -- white is not good enough
as a first assumption
sweatybetty89
morehead ky
It sounds good. This was a mock up to see if she fired and idled. Ol beatty does. Now it's time to pull the motor and start working on the frame and suspension. Get my wiring how I want so we are moving forward. Parts to order things to do. Winter here we come
nj1639
Paleo-simplistic
Switzerland County, Indiana, U.S.A.
I'd tell a newb to the xs650 to note which bundle of the harness goes to which side of the headlight bucket, its almost immaterial but....also removing the battery box can be a Chinese puzzle. It goes out one side and not t'other, twisted OR out the rear when the tire is removed if I recall correctly, it's been a while.
