Thanks for the posting the last image sealed the deal for my CDI unit , bk wire is ground 100% known, Bk/W has same continuity to capacitor as bk , seems like ground cut wire out to side stand and drawing confirmed that
It is a TCI unit, not a CDI............another thing. I notice you refer to the bike as 79SF. whatever your paperwork says the bike is an 80SG. Different carbs, (BS34's), Has an Factory electronic Ignition, (TCI), clip on seat and different taillight/number-plate light and speedometer
Quick question about the first diagram. Does the safety relay connect to the otherwise capped off yellow wire from the alternator? If not, where does the yellow safety relay wire go to?
Also, this diagram is so incredibly helpful. The fact that the charging and ignition blocks are interchangeable according to the model year is brilliant. Hats off
Yes it does. It is used to stop the starter motor from spinning once the engine is running. hence the safety relay, prevents damage. The yellow wire is from the generator.
