Source for Swing arm through Bolt.
albeix
Kaslo, BC, Canada
When I removed the swing arm to replace the worn out bushings with Needle bearings (more on that in a minute) I discovered that the bolt had at some time in the past snapped at the top of the threads and been rewelded back on. Not something I would want to be riding on. Been trying to find a source for said bolt without any luck.
Anyone know if a reliable source for this bolt, or an alternate that works and is available??
As for the All Balls needle bearing swing arm kit I cannot recommend this kit. I installed the two bearings one side and then tried the bolt in them to check their fit. They are at least as sloppy as the old plastic bushings I removed and possible worse. Hence I will be going with Bronze bushings but need a new bolt.
All input gratefully received.
MacMcMacmac
Failed Hedonist.
Ottawa,Canada
Yup. I put the roller bearings in my swingarm and the rear end suddenly seemed very vague in the handling department. It was too bad, since I spent a rather tempestuous few hours pulling out perfectly good stock plastic bushings to install them.
Jim
XS650.com Supporter
Kansas City Mo.
A pivot that only rotates about 10-15° is not really an ideal application for needle bearings.... unless of course you're a 2stroke piston with the high rpm reciprocation component thrown into the mix. But a swingarm? Not really.
From a engineering standpoint something like.... oh I dunno... a brass bushing would be more suitable. :sneaky:
:twocents:
gggGary
Simplest truths meet the sternest resistance F D
XS650.com Supporter
Baraboo, WI, USA
:twocents:
To bad you weren't a consultant for BMW and their para-lever swing arm design.
gggGary
XS650.com Supporter
Baraboo, WI, USA
Jim
XS650.com Supporter
Kansas City Mo.
Can't tell what I'm lookin' at in the top pic.
Bottom looks like a U-joint. Standard fare for needles. :shrug:
gggGary
XS650.com Supporter
Baraboo, WI, USA
A small-ish tapered roller pivots through a mix of 7.5 degrees and carries the most of the rear load.
Brinelling city. They've been using the same bearing for about 2 decades now. Prices have recently doubled from the previous nose bleed $$.
I suspect my Gs is showing signs it's time.
Grewth
UK
Every bike I've had with rollers in the swing arm has been trouble.
GS750, GS1000, Z250.
The slightest bit of moisture past the seals and rust kills them in no time.
They seem determined to rust out even when greased regular.
You can't beat bronze bushes IMHO, although there's probably some room for debate about which materials are best.
How about Oilite bushes and a stainless inner sleeve ?
Jim
XS650.com Supporter
Kansas City Mo.
You've got a lathe. Make some bronze bushes for yours? Oilite maybe...
arcticXS
XS650 Guru
Tromsoe, Norway
Regarding the original thread subject, didn't someone recommend the swing arm bolt from a Suzuki GS 750/1000/1100?
(750/1100 from 80 onwards were named GSX in Europe)
