"SPARE TIME"
phil240
staten island, ny
Over the years I have learned a bit and started off little by little making parts. As you guys know I bend tube for the brat kits and make electronics boxes for the barebones harness kits. I've become more confident in my skills and welding ability. I am by no means a professional welder. But last summer I picked up a clean low mile 79 and decided this was going to be the donor bike.
So with a good solid base to start and a very knowledgeable friend to help me out the build began.
Below is how the bike looked when I first took it home.
I knew I was going to need a solid table and also a frame jig. So I went and made my own table. It's a fixture table, welding table and can be used as a frame jig.
This is the table being built and helping me work on my welding a little more. I used my Langmuire plasma table to cut the top. I'm limited to just under 2x2 sheets to cut. And I played with design on Onshape to help with the cad.
Next up I finished breaking it down and set up the frame jig. I made sure everything was square and level. Then I set it up in the jig and checked again for square and level as I set it in the jig.
I went through a couple different axle plate designs and finally was happy with one. I'm a little past this point now but don't want to give away the rear design yet. So I'm stopping this here. But I will let you know took the laser to measure and everything is square. I'll be working on things through the month and will post some updates soon.
Has anyone played around with building their own vibratory tumbler?
I'm thinking of making one large enough to do the wheels, but with 3 sections that way I can go from aggressive to a fine media.
Was thinking along the lines of this one https://laserbros.shop/products/tumbler-kit
Was going for that style tub, just modified a bit to fit the wheels and have 3 sections. Then suspended to a frame vis trampoline springs and use a concrete vibratory motor.
Any input or experience?
Still not 100% on what I'm doing battery box and electronics box wise. I'm trying a couple different things. Idea one of a horseshoe style is already in the trash. Currently thinking of doing a separate battery box and electronics box. Still developing the electronics, but went with a windowed battery box for the 8 cell lithium ion. Currently in the cardboard design phase.
The electronics box is a go. Made this one out of 1/8th in this weekend. Lid will double as a mount for the solo seat. So I'll be cutting off the the original planned seat and spring mounts and setting up again.
Just an update for everyone. I haven't put any time in on the bike lately, work and family has taken precedence. I did get in the mail the front half of the exhaust from Pandemonium Choppers. I went with their Hustler exhaust and I plan on making up the back half myself.
I also plan on making up my own set of floorboards for the bike. So I need to set up the seat, set up the exhaust, figure out the floorboards and then work on making up the controls. I know what I want and plan on making it work, but sometimes these little things take a while to figure out.
Remember how I said the seat was driving me crazy and I wasn't to happy with it.
Well decided to try making my own. The seat pan is roughed out. Once I finish this I can work on foot controls
