Hi all, I am going to do a order for parts and had a specific question. I orderded both the clymer manual and Yamaha XS650 engine manual, but now need to get some parts. For changing the oil I was instructed to get conventional 20w-50 or rotella 15w-40, and to drop the sum plate to check for damage. While there I should replace both oil filter gaskets right? I am also going to order a UNI Air filter - https://www.amazon.com/Filter-Strai.../B001IWUZ8G/ref=pd_lpo_2?tag=usdeexplicits-20 - Is Straight Mount / 2-1/4" X 4 the generally used size?
Once these are on I am going to see how it runs and adjust carbs if needed and then move onto rebuilding forks/fixing the clutch
Also is there a way to diagnose the clutch when I pull it in its hard to pull and gives power weirldy
Thank you for all of the help and advice!
