Sky King
I got another shake down ride in today, 40 some miles of mountains and twisties. The bike ran good and I think the carbs are sorted, the clutch still leaves a few things to be desired so I'll be working more on that, but what stood out on this ride was the stock gearing, it was too high for my liking. To get to the highway from my house I have to use a rough steep dirt road, first gear is higher than I like for that terrain and also for the town portion I did when I went to get gas. The previous owner replaced the chain and it's a bit on the short side so I would like to change the front sprocket as an extra tooth or two in the back won't work with the short chain. So from the stock 17 tooth front sprocket I would like to drop it one tooth or two. I know I will loose some top end but the question is how much and which would be best a 16 or 15 tooth sprocket. What sort of 1st gear speed and top gear cruising speed can I expect with those changes?
