Hi guys,
Need some advice.
I just installed a starter after rebuilding the engine. The starter is turning over fine but the Bendix is engaging and disengaging. I found that this is a common problem.
Here is a video clip i made of the problem:
The starter gear/clip & spring are brand new. I measured the drag of the clip, according to the forum it should be around 6lbs. I measured 5,4 lbs.
Should I try to pinch the clip to increase the drag? Or could it be something else?
Need some advice.
