Starter bendix shaft countersunk screw?
fox23
Edmonton, AB
Can anyone provide me a part number or source of buying a new pan head countersunk screw that goes into the shaft base of the starter bendix? pics below... thanks guys!
What parts fiche did you find that in Carbon? I look through them all and couldn't see a PN indicated anywhere.
If its just a normal 6mm pan head bolt I have no problem getting it at a hardware store, I just don't have one on hand to see if there is anything special about it.
Why do you need that bolt? Did you remove it? I can't see any reason to remove it.
No idea why it was removed, basket case engine I purchased like this. I was doing an order of a bunch of SS bolts for the rest of the engine, so I just added a couple for this and hopefully one will work. A standard M6x1.0 threads in about 12mm.
