cliffhanger9
XS650 New Member
I have an all original, stock, bought from 1st and only other owner, 1981 yamaha xs650 special
It ran beautifully. Electric start but started within 2 kicks if started that way. One day I was riding and it just shuts off and dies. I coast to a stop. Turn it off. Turn the key back on but nothing comes on despite being in neutral no lights, no nothing.
Battery reads 12v when its disconnected from bike but when connected and turn the key on reads 0 or 1v.
Pressing start button does nothing and bike will not kick start on either in this state.
If I leave the key in the on position and walk away there's a chance some magic has happened and the taillights and green neutral light will have come on without anyone touching anything in my abscence. Check voltage, back to 12v. If i press the starter button, I hear the started solenoid click and the lights go out everytime back to nothing, no voltage reading on the battery.
If the light magically comes back on 5 or 10 mins later, and i kick it, sometimes it will start and runs fine (seemingly, never have taken it farther than around the block because if it were to die again, getting it to start again is unreliable.) But this proves that the mechanics and fuel systems of the engine runs and seems to assuredly be an electrical issue. If I leave it on to idle and check battery voltage while running voltage reads between 13-14v so seems like alternator is running. And after it sitting for a couple months the battery still reads 12v without trickle charge so it seems the battery is heathly. I'm not sure what else to check now. I've unplugged the headlight, and the start circuit cutoff relay and neither of these conditions makes any difference. Any recommendations on what else to try troubleshooting? Friends have recommended check for a loose ground but this is my first experience troubleshooting a DC system as i've never had any issues with this bike before, (first bike) . The battery to frame connection just behind the battery is tight.
Any guidance greatly appreciated.
