I have done the following things.
Timing chain adjusted.
Valves set to 0.002 on the intake and 0.006 on the exhaust.
The static timing marks for both cylinders set to specifications.
Full advance mark lines up.
Some questions I'm not sure about.
Can accidentally grounding out the points with ignition on cause anything like a fuse to blow.
I have verified that I do have spark on both cylinders and I have fuel to the carbs.
I did start to take off the points cam lobe and was unsure if it was left hand or right hand threads . could this have caused any issues?
When I crank the bike over now absolutely nothing.
Any comments would be greatly appreciated.
