steveair2's '78 XS Chopped Hard Build
Today I did some filling, priming and sanding.
Then I started working on a tail light wire/fuse housing retaining bracket.
Today I took a break from filling, priming and sanding I worked on the tail light wiring and the tail light wiring housing mounting bracket.
Today I completed most of the welding on the axle stay/tail light mount and installed passages for the tail light wiring.
This morning I did some filling and sanding and worked on some wiring details. Also made a little progress on my trailer hitch and flag pole mounting points.
Tonight I welded in the four license plate mounting studs and the trailer hitch, flag pole mounting points.
And for my next feat, I’ll be Sanding orange peel and overspray.
Today I laid down some really smooth paint, in three or four spots by accident.
Other than that it’s mostly more orange peel and over spray. I suck at painting.
I let the second coat of paint cure for six days before wet sanding. Sands much better but still sanded through to the primer in several places again. Still much more sanding and touch up. It’s more work since I’m not putting any clear over it.
