nhsteve
The bike: 1974 TX650A. I rebuilt about 8 years ago from a very neglected state. Motor had been torn down and "rebuilt" at some point, but outside wrist pin clips were left off with catastrophic results. 2nd O/S pistons/rings, etc. cleaned this up. Valves looked "ok" and measured within specs, and I could feel no slop, so I (foolishly??
) left the guides in place, installed new seals, lapped in new valves (went fine), & reassembled. The vendor I used for all the parts was indeed Mikesxs. Carbs were replaced with a set from a '78 standard (linked together as you may know). This was because a P.O. had chromed the float bowls and getting the small jets out was impossible due to the chrome, and they were plugged (so, upgrade, right?). A later cam chain guide assembly was used to accommodate this change. Carbs ultrasonically cleaned and all OEM parts used to rebuild the carbs. Points ignition, standard charging system (new bits all around). Bike started, timed up, carbs synched, ran GREAT. I am using non-ethanol hi-test fuel and the oil is Yamaha 4T mineral bas, not synthetic.
At around the 400-mile mark, just before I was going to do an oil change, I was riding up a very steep, very long hill, and the right intake valve stuck open.
Get the bike home, open it up, pulled the head off and sent it to Bill Bune in Anoka MN (I have used several times, good guys). They replaced the offending valve and guide, using the same valve type I had used already (Mikes'xs again, thinking to keep the bits all the same).
Fast forward to last week. Bike has done another 800 miles (after the rebuild at the 400-mile mark) and still runs fine. Pulls well, no surging or fluffy running. Compression is 145/150 PSI L-R. I double checked/reset timing this spring (well, May). The last two or three times I have ridden the bike, I have started to notice going up some very steep hills that the bike "catches" momentarily once in a while. One time it did so 4-5 times in a row but really kept running fine. My wife even picked up on it and remarked when we stopped. This really doesn't seem to me to be either ignition or carburetion, but....?
I am indeed kicking myself for not having the other 3 guides done at that time.
I would appreciate any thoughts on this. I am not looking to do another tear-down (I was/am considering selling on, as I have several other bikes). If it truly is a potential sticking valve, could a lead substitute additive to the fuel help out? I tend to not do that (although I do use fuel stabilizer overwinter).
I know there are a lot of really smart guys on the forum whose opinions I respect.
Any feedback? Suggestions?
Regards gentlemen!
) left the guides in place, installed new seals, lapped in new valves (went fine), & reassembled. The vendor I used for all the parts was indeed Mikesxs. Carbs were replaced with a set from a '78 standard (linked together as you may know). This was because a P.O. had chromed the float bowls and getting the small jets out was impossible due to the chrome, and they were plugged (so, upgrade, right?). A later cam chain guide assembly was used to accommodate this change. Carbs ultrasonically cleaned and all OEM parts used to rebuild the carbs. Points ignition, standard charging system (new bits all around). Bike started, timed up, carbs synched, ran GREAT. I am using non-ethanol hi-test fuel and the oil is Yamaha 4T mineral bas, not synthetic.At around the 400-mile mark, just before I was going to do an oil change, I was riding up a very steep, very long hill, and the right intake valve stuck open.
.I am indeed kicking myself for not having the other 3 guides done at that time.
Regards gentlemen!
). Full replacement solved that one. So I will revisit my clutch adjustment also.
