ninskrillz
- Messages
- 271
- Reaction score
- 67
- Points
- 28
Hey guys
Hoping to get some help with an issue with my latest xs650 project.
I just got my bike on the road after working on it for about 8 months. Starts easily, idles great and pulls strong! Up until about 4-5k rpm that is! Then it stumbles and sputters until eventually gets through it or I upshift and its smooth again.
Although I don’t know the year of the motor, I bought it from a fellow who had it built with a 277 rephased crank, shell #1 cam, and 700cc pistons. Included with the motor was a set of later model BS38 carbs and a Vape/powerdynamo ignition. I have since replaced the carbs with some VM34s.
I feel like I’ve done everything I can to solve this high rpm stumble to no avail. I’ve hosed the thing down with WD40 to check for air/exhaust leaks, changed jets, sync’d and set carbs, changed plug wires, resistor caps with regular plugs, regular caps with resistor plugs, changed carbs, adjusted timing and nothing seems to have taken care of the issue.
Compression was 148/150 and other than the high rpm stumble I’m happy with the performance. I’ve never used a CDI and I’m pretty sure that this is an electrical/ignition issue.
Any help is greatly appreciated!!
